With ice age, (and theoretically) BDX and mtnside making lift kits/spindles for arctic cat, I've been thinking about ways to lift the front of the skid. I can't redrill the tunnel without putting in an additional reinforcement plate.
If you have a coil front track shock, it looks like can buy longer eyelets from fox, gaining about half an inch there. Similar to what raptor just released for the axys sleds to get more khaos like.
I was looking at pivot locations between a polaris and my proclimb and the cat lower shock mount is pretty close to the lower front arm mount. Moving the bottom shock mount forward would give some extra height without and shock diddling. This looks like it will lower the leverage ratio on the shock so you'd probably need to drop some pressure or back off clickers if you got'em. But you'd get some ride height doing that and extending the limiter strap some. It's something that can be undone too so no big commitment. Anybody know what the stock length of the limiter strap is on a 2016?
I just stuck some walker evans ski shocks from a 40" width axys on and got half an inch of rise. That plus the BDX or mtnside spindles would give the 3" ice age has accomplished.
Thoughts?
Fox - Shaft Eyelet, 1/2" Shaft x 1.49" Base
Includes (1) Eyelet Dimensions 0.498" Shaft x 0.7" W x 1" Eyelet x 1.49" 1.76" L Fox Part # 808-01-000-A 2.01" L Fox Part # 808-01-001-A 2.26" L Fox Part # 808-01-002-A
www.hygearsuspension.com
Thoughts?
