Havent removed the radiator yet. But its in my plans. I just have to get all the necessary parts.Have you removed your front radiator? If you haven't I would look into doing that.
If you have, are you positive you bled the system really good? If there is air still in the system you will run hot.
Temp wise my sled runs about 115 to 125 off trail and anywhere from 130 to 145 on really hard stuff. You definitely need to get some regular scratchers, from what I have seen the ski scratchers don't throw enough AT the coolers, instead more towards the panels. Regular scratchers will get the snow into the track and then thrown at the coolers.
130 off trail in powder is high but temps 150 and below are not going to do permanent damage. I have ran that high in the crappy snow in ND, if I get anywhere near 165 I stop and kick snow on the coolers.
Thanks for the info. I didnt know that ski scratchers wouldnt do as good a job... Regular scratchers are deff on my todo list.Ski Scratchers are for lubricating your hyfax not cooling your sled. Rail mounted scratchers do a much better job of throwing snow at your coolers. I also found that when I ported my track the snow was thrown from the holes in the track to the cooler and my temps dropped 10 to 15 degrees.
Saw 160 today on hardpack before i shut her down to cool down. 120s in the powder. Definitely time for scratchers.
