Three and a half years ago was an exhausting stuck for me to remember. The snow was wet, heavy, mashed potatoes.
So's I'm standing beside Corey's [best bud] sled and the middle of his left side panel, i'm almost eye level. Lookins at this stuck 165 mess, I says to meself, and, out loud to Corey, “that’s it, I'm done with this ski tent polling bull....”.
If Corey had a good set of ski damper rubbers, we could pull the sled back more, having room to counter steer, rolling it over.
Three and a half years later, after a lot of time/effort/energy/research/testing...etc, here I am with the iSidehill - Ski-Doo Ski Damper Rubbers
These Ski-Doo Ski Rubber Dampers are made to take up the clearance in the ski-to-spindle fit. The Ski-Doo Rubber Dampers are a tight fit.
Made to still be functional at -20C (-4F)
This Ski-Doo Ski Damper Rubber ONLY FITS the 2017 to 2024 Ski-doo Summit DS3 & DS4 ski with the 3 inch keel.
This Ski-Doo Ski Damper Rubber DOES NOT fit any XM/XS DS2 ski, and does not fit any LYNX.
Better steerablity
Keep sled on its edge, easier sidehilling
Less lateral slip, flatter skis, engage snow better
Less resistance for Balance to steer
Dampens handlebar feedback, steer to balance
Ski tail holds snow better, carve harder
Less pitching, float higher, float smoother,
Ski rocking dampening, flatter sledding
Stops ski hitting your front bumper, less porpoising, more stable front end
Getting unstuck
Stuck, hill, skis don’t tip up; flatter skis, pull sled back farther
Cornered in trees, 10 point turn (haha), skis don’t tip up; reverse easier
Skis don’t tip up in deep snow, back up farther, get a better run. [VICTORY ]
Sled on side; stand on ski edge with confidence, better balance.
Sled on side; stand on the ski bridge cleats, pull on your handlebar [stable boot grip]
Sled on side; two friends pull the skis, equalized pulling
Tire Art Wood Bumper Audio equipment
If you go to read the page, make sure you read "background story".
Better steerablity
Getting unstuck
This Ski-Doo Ski Damper Rubber ONLY FITS the 2017 to 2024 Ski-doo Summit DS3 & DS4 ski with the 3 inch keel. This Ski-Doo Ski Damper Rubber DOES NOT fit any XM/XS DS2 ski, and does not fit any LYNX. Better steerablity Keep sled on its edge, easier sidehilling Less lateral slip, flatter skis...
www.ibackshift.com
