Has anyone heard of having to re-program a Brain Box from a Doo sled when adding Twin pipes??? I have twin Split Second pipes and that was what I was told... anyone with Cranshop Twins have to reprogram the brain box with twins??? I was told that since you need to run higher RPM with the twin pipe set ups that you need to have your brain box reprogrammed or else you won't be able to hit the 8300-8500 RPM range... this sounded odd to me since you should be able to turn more RPM with the same clutching due to the increased hp... not to mention you can change your primary to give you more RPM...
anyone heard of this? Is this dude on crack or is there something to it?
