Be prepared for more snow. More snow is coming. Instead of being without a clutch kit for a few weekends, get one now, prepare, be ready.
When you're finally out there you'll say "I’m glad I got this clutch kit".
...make that hill because;
In 5 minutes, a quick tune with the change of a bolt and spacer.
Installation tools available
Install instructions, print and video
Technical troubleshooting skills
If you're a blipmaster
and blipitlots
with our kit, you'll blipitless
Make it farther than you thought and look really cool DOOing it.
Add a set of "iSidehill" Ski-Doo Ski Rubber Dampers [10% off with a clutch kit]
Set your sights on going across your sidehill
Confident control, your front end doesn't porpoise.
Make it to your mark, then the next mark, then the next one, in better control.
Use better rubber to spindle contact to back up farther without the ski getting stuck.
More run for pin-n-wiggle it.
Combine a clutch kit for more track power and the Ski-Doo dampers for handling, You'll make more moves, go farther and be less tired at the end of the day.
www.iBackshift.com
www.iSidehill.com
Multiple kit discounts - discount page
Customer feedback page - reviews
Two of the biggest bangs for the buck is a competent clutch kit combined with good ski damper control.
- Put more power to the track
- More track speed to make it
- Tighter throttle to track response
- Smooth control in the trees without trenching
- Feather stop and start
- Move better slowly and in more control
- Able to crowd over the handlebars without surging
- Smooth clutching, track bites the snow
- Smooth throttle, keeps the sled on edge
- Easy to regain control in a washout...wheel up to bowtie
- Cooler clutch and belt temperature
- Smoothest engagement
- Quicker backshift
- Strongest engine braking
- More track speed
- Make it farther
- Pulls hard to top
and blipitlots
www.iBackshift.com
www.iSidehill.com
