D
doc1
New member
Here is a new build, it is named Project Sinister. This build is brought to you by Busted Knuckles Racing. Check us out on facebook.
https://www.facebook.com/BustedKnucklesRacing
Sponsors
C3 Powersports
Full Power Performance
Ice Age Performance
Proven Design Products
USI Skis
Monster Performance
Boyesen
Nextech
Carbon Sled Parts
REVS Full Throttle
Here is the C3 2" XM Post Forward Kit Install.
Here are the parts to the kit. This is the original post forward kit C3 has been making post forward kits since 09. This is of course the XM version.
This is the C3 Powersports Carbon Fibre hood. This hood is an extremely high quality piece. It shaves 13 lbs over stock. It has an optional headlight and airbox assembly not shown in this picture!
Here is the hood with some crazy blue lighting on it at the Toronto International Snowmobile show.
Here is the Full Power Performance Pump gas low elevation turbo kit. This kit features a low boost pump gas alternative to many kits that are run at high elevation. The boost can be run as low as 3.5 pounds for 195 hp at sea level elevation on premium pump gas. It can also be turned up for bigger hp levels with the use of higher octane gas all the way up to 285 hp.
Also noted the C3 Powersports Synchrodrive using it for the second year on this new project!
Sponsors
C3 Powersports
Ice Age Performance
USI Skis
Monster Performance
Boyesen
Nextech
Carbon Sled Parts
REVS Full Throttle
