SO many good points in this.I have ran both set up, external and internal. The internal is more of an explosive boost and the external has a softer slower more stock like feeling with large top end. Most people who ride in the deep snow like the slower boost hit over the booooom. In the trees the boom is harder to handle as well. Now a external can be plumbed so it hits hard like a internal. I have spent time on the the phone with tial tech understanding why my sled is not explosive.. I also learned a few things from a CAR guys too. Plumbing the gate as I did (top and bottom) with a ball and seat type controller makes the sled feel smooth. When you put a restrictor pill or bushing in line before the controller (vent to atmosphere gate valve), it holds the wastegate shut longer creating the explosion. Now the smaller the spring in the gate the sooner the boost will overcome the spring and feel smooth. Now a electronic boost controller shuts off the line to the gate forcing the gate to rely on the psi of the spring. Now some guys want to be able to turn down their sled to 5 lbs to run pump gas in the event they run out of good gas and need to get out of the mountains... borrow gas from a stocker.. The beauty in this is its possible as their are 25 different psi springs for the external gate.. There is a lot more to the external plumbing than a internal.. pm me if you need help..
Jim
Also, a programmable boost controller combo'd with an external gate gives a guy such an impressive range of power delivery and boost levels at the push of a button.
Got to test The protoype external gate from justin last spring. went right from 7# of boost on the internal gate to 7# on the external. First thing I noticed is due to that smoother hit is in the trees when chopping the throttle is that it would no longer boost spike and randomly hit the rev limiter when on and off the throttle fast. Huge plus. Also, I found that because it came on smoother I was able to ride with less effort as the sled was less all or nothing. Much more stock like feel and easier to control. Still VERY fast on the top but that smooth transition made it much more pleaseant to ride and less trenching/stucks when taking off in tight spots with low ground speed.
