Silber Turbo Pro Working great! (most of the time)
Keep in mind also that people are very quick to assume things in this forum. If you take 20 guys with very little experience working together to solve a problem,you may get it right once in a while. The problem with the is sometimes you get it wrong and you head down the wrong path. I am sure all the turbo builders would prefer folks avoid asking questions to other folks on the web because it leads to more problems than it helps sometimes.
I can also appreciate that sometimes SW is all you have in a pinch.
Emailed justin a couple days ago with my problems but hasvent heard anything yet. I guess he's got alot of work on his hands right now, so ill be alittle more patient.
Probably getting my race fuel tomorrow, so ill will try with a couple gallons in the mix and see what happens.
Did you put the low pressure wastegate spring in? Turn the boost down to 3 or 4 pounds until your race fuel arrives and see if you still hit DET
Yeep, im using the low bost spring. Nah im just going to wait to tomorrow when i get my race fuel, aint going to ride today anyways :)
While you don’t want to be hitting det. The sensors are so sensitive on the pros that you can hit it thousands of times on this motor w/o damage.
Yes I can read, and "hitting the det thousands of times w/o damage" is in my book not true. It may be ok for you but I would not say its ok for others. Thanks for the bad Rep.
I am fairly certain his particular sled did hit DET that many times.
I certainly don't endorse people ignoring the sensor, When the sled is right you wont see it.
