Silber Owners
friscospices.com
Who is going to re-install kit this summer to check for issues and try to get better mapping from Justn if its available? Justin is there a better map out there for the 2012 kit? Both maps would be needed for the 2011 sleds with the 12 kit and the 2012 sleds with the 12 kit? I hope Jusstin can chime in here before Docks need to get installed.
I would take it off. Change the oil before you put it away and enjoy your summer.
Justins map works well all over, that it what he needs it to do.
Ours works better up here but may be too lean for other places and is a "run a your own risk" Whenever you are around I will flash it for you. Not looking good for this year though. I will try and get a bench deal going so I can flash them without the sled then you can just mail it to me.
The auto tune feature will also hopefully be working for next season and that should help a bunch but it will also require a reflash probably.
Im going to buy a boost it box. Then i can make my own map. I dont want to mail my box and wait and see if its better or worse.. I dont see much need in removing the kit but wouldnt hurt i guess.
4
this will be the fourth or fifth time ive torn mine down but i probably would have done the same if it were running right too just to keep an eye on things and check my reeds. this time i need to order some viton o rings and grind off the sharp edge on my throttle bodies. oh and pound my tunnel back straight with a dead blow, im going to wait for a couple weeks cause i just got my new afr sensor now i can maby tune out the bog
Justin
Hey buddy do u think I could order some of those parts that I have been trying to order from u for the last 2 yr? I think the flash in my box is working as good as it gets so we won't worry about that. So yea, hoping Silber will chime in.
I'm going this route as well. The silber kit works great, turbo spoils.quick, etc. I just want ability to fine tune the map to my liking
I am going to remove mine put in new pistons/rings and wire in a plug so I can remove the Doebek Controller by just unplugging it. That way if there was an issue with a controller it can be switched out in minutes. Been thinking of getting a spare maybe have Bostons map in one for elevations above 9k and use Justins map for everywhere else below the 9k. Not sure if it would be worth the coin to have a spare.
How is that auto tune working?, how does it exactly work, you set your desired AF ratio for the mode colour and it will adjust itself in every "X" ammount of the missed preset value?
