Silber 2012 Pro RMK 800 Kit $3000 Shipped
Here are a few key features of the kit:
New Silber turbocharger, engineered for the 800cc two stroke engine.
Plug and plug electrical components
Muffled exhaust pipe
Optional air to air intercooler/ with integrated Fan and Blow off valve
Billet o ring fitted throttle body boots, with integrated additional injectors. And o ring fitted air box/ or intercooler that bolt to the billet throttle body boots.
Complete list of included Turbo kit components:
Silber Turbocharger custom engineered for 800cc two stroke engine
Billet waste gate, with low psi spring and standard psi spring included
Oil tank mount with roll over valve to eliminate smoke when upside down
Aluminum Oil tank, with sight tube.
Custom threaded and dual vented oil cap
Cold air intake, with stainless filter cage.
Outer wears Pre filter
Stainless filter clamps
2.5” Exhaust down pipe with muffler
Socket head exhaust bolts
Pipe to turbo stinger, springs to stock pipe( no welding required).
Stainless turbo inlet gasket
Just had baby and need to sell ASAP!!!
Custom micro military grade oil pump
Pre cut and assembled oil lines, filter and fittings
Turbo coolant hoses and fittings
Aluminum charge tube
Billet Boost controller
T bolt charge tube clamps
Black charge tube couplers
O ring fitted air box, with intergraded Blow off valve.
Billet Throttle body boots, with intergraded fuel injectors
Plug and play fuel control box, no splicing or wire cutting.
Boost Gauge
Optional AEM wideband gauge
Aluminum handle gauge mount bracket
All nuts, bolts and springs.
Precut boost lines and fittings
Turbo clutch kit with adjustable weights
2012-02-25_16-15-15_384.jpg 2012-02-25_16-15-21_319.jpg 2012-02-25_16-15-23_329.jpg 2012-02-25_16-15-31_604.jpg 2012-02-25_16-15-39_264.jpg 2012-02-25_16-15-43_154.jpg 2012-02-25_16-15-13_610.jpg
