The airboxes for my 99 summit 600 is the biggest pain in the a**. Are there any good aftermarket air boxes that are smaller than the stock box and actually fit. Or could i just run single air pods off the carbs?
put some filter pods (filter skin makes some good ones) and forget about that junk the only way you are gonna get more air into a engine is if you force it in there no filter box is gonna make air flow better then wide open. It does effect the way the altitude compensater works thats why ski doo cautions u not to remove. if there is a altitude compensater i would recomend getting rid of that too never worked good to begin with. Stock box is there to muffle the intake noise so people dont here the noise and create backpressure for compensator.
do not listen to a word in this reply. These are not 4 stroke motors like your car. As stated above, the stock airbox is tuned to work with the "pulses" your motor creates and give you peak hp and the motor's idea rpm. Don't cut it or change it in anyway, just deal with it
You can believe whatever you like everyone is entitled to there own opinion heck i might even be wrong but knowing what i know about 2 stroke engines the exhaust is the fundamental part in pulling air and fuel into the engine and a clear clean and dry intake track is key to efficiency not a maze of baffles designed to make backpressure. A engine is simply a vacuum pulling air and fuel in and pushing spent gasses out. There is a good reason aftermarket companys make good money constructing ways it improve on the intake track to delver clean unobstructed paths for air . You can take my advice for whatever its worth.
Again, a 2 stroke NOT simply a vacuum. You are talking 4 stroke talk. 2 strokes work largely on "pulses" which as I understand it has a lot to do with the sound waves that are created in the combustion process. These are a completely different beast that a 4 stroke where the less resistance on the intake side the better. And there are not that many aftermarket manufacturers that attempt to improve upon the ski-doo airboxes, because there is no point. Slp is one of few, and they simply use a different way to deliver the air to the stock air box. This has a lot more to do with people's oppinions, this is the mechanics of a 2 stroke motor.
