Shrouds/Eng Jacket/Covers
summitboy
Lets start a thread on shrouds. Show us what you got and a description if you can. Please let us know what materials you used etc. I see some using materials that aren't melted by 2 stroke pipes etc. Hard or soft material and any other good info u have !
Should add "Engine Covers/Jackets" to the title. At first I thought it was the rad shrouds you were talking about.
Im using something call Aerocell for mine. Ill be building it this week and post the build and finish product end of the week.
Shroud
I picked up my skid plate and shroud from J&L snow hawk here on the forum there some kind of synthetic plastic put a sticky heat shield on one side where the exhaust goes they work great and I think he has a pattern for every bike out there.
Shrouds
I use fire blanket on my ktm 570 you can get from acklands ,orange in color soft an flexible like a tarp water proof an can lay it right on my exhaust header or hold a propane torch on it an will not burn
I used some 1/8" puck board . Easy to cut with tin snips an mold with a torch
I used hydro-turf from my jet ski days on the left side of my YZ, Zip tied at the front and tucked behind the frame so I can pull it out without tools to access the carb and dipstick.
shrouds
this time of year in deeper fluff, cooler riding days, I like running an engine shroud to keep the snow off that big aluminum motor. Even with thermostat, radiators covered, there are morning when snow flowing over the motor just sucks the heat out of the motor.
Like many I run a pretty tight shroud on the left side of my yamaha, hole cut for my transmission fill port ( waste of time you can't get in to screw the cap off ), holes for air screw and idle screw on the carb , hole for remote pull choke, and cut low around my petcock.
Right side nothing. What we found by riding powder on the road and observing a bike that wanted to freeze/ice the carb all the time was, powder was hitting the hot pipe turning to slush and blowing back onto his Keihin carb, the melted snow/slush was super freezing from the 40mph speed and carb icing was happening. The cure was simple, we wrapped the pipe and sparyed it down with 10 coats of silicone paint, no more carb icing. So should you wrap the pipe or not, there was one time on KTM where pipe wrap was great. No carb heater on that bike, three years of handlbar powder, no icing/and no extra plumbing. Also found that on KTM with Desert tank, so much of engine and carb was covered, no carb icing after big tank was installed, however still a left side cover on those big powder days. Picture is cover I made 4 years ago on the first bike I built, still running same setup on yamaha engine...........nothing has changed.
I hang some allstar rolled plastic on the side and then heat it up with my torpedo heater till it gets nice and soft. I then hold it up against the engine with my hands (two pairs of gloves) and let it cool off. I touch up the shape with a MAPP gas torch. If I cared and spent more time I'm sure I could make them pretty, but one ride in the backcountry and the bike isn't pretty anyway.
Bike feels as narrow as it does stock and the shrouds keep all the snow off.
I double wrapped the header pipe and unless I let the bike idle for 10 minutes the plastic up against the pipe doesn't get soft.
