J
jTrue
Sorry for the novel, new to carbed 2 stroke motors. So I just purchased an 04 Mountain Cat 900 a couple weeks ago. When I would get into deep snow it would bog very badly. I riveted another stock snow deflector onto the original deflector. I also plumbed a snorkel to the speedo hole and gutted the airbox. Also put a ring of rtv around the exhaust outlet to seal it, so exhaust didn't come back in. Just took it out this weekend and it seemed to run a bit better, but still not getting the power I think I should and it's still bogging a bit.
I ride in Utah about 8k to 10k feet 0-20 F. Usually run a mix of 110 and 91 for a final octane of around 94-95. I was told a squish measurement was taken and it was on the edge between pump/race gas.
I checked the plugs and it looked like I was running pretty rich even after the snorkel/airbox gutting. I pulled the carbs and checked the main jets, 480 PTO / 470 MAG side. This seems really high compared to what others run with a similar setup at the same altitudes/temps. I know every sled is different, but this seems excessive. I have a KOSO Dual EGT gauge on its way, but should I be ok dropping down to 460 PTO / 450 MAG to see if the bog clears up? Appreciate any help.
Mods are as follows:
Black Magic Heads Pump Gas Insert(anyone know listed CR for these?)
SLP Twins Pipes and Silencer
Bored Carbs
VForce 3 Reeds
Gutted airbox
Snorkel to speedo hole
Bored Carbs
VForce 3 Reeds
Gutted airbox
