Also from Poo service manual:
IGNITION TIMING
Timing Procedure - Carbureted Engines
NOTE: Always verify timing of engine at room temperature (68°F / 20°C), and at the specified RPM. If applicable, make sure the key switch is in the PREMIUM mode and the TPS is unplugged.
1.Reference the timing specification chart.
2.Install a dial indicator gauge into the MAG spark plug hole.
3.Place the MAG piston in the proper timing position, then mark the flywheel at this point.
EXAMPLE: 600 HO Carbureted = 26° @ 3500RPM. Place the MAG piston 4.0096mm (0.1579in.) BTDC.
NOTE: Each 10 degree mark is separated by lines every 2 degrees (not shown). Acceptable timing variance is +/- 2 degrees.
4.Connect an accurate tachometer and a good quality timing light to the engine according to manufacturer's instructions.
5.Disconnect the throttle position sensor (TPS), if equipped.
6.Start engine and increase RPM to the point specified in the timing specifications. Hold the throttle to maintain specified timing RPM.
7.Point the timing light at the timing inspection hole.
8.With your head positioned so there is a straight line between your eye, the stationary pointer and the crankshaft center line, note the relative position between the marked flywheel line and the pointer. If the stationary pointer is aligned with the mark made in Step 3, or within the acceptable variance, ignition timing is correct.
9.If the pointer is outside the variance, the stator will have to be rotated either with crankshaft rotation (to retard the timing) or against rotation to advance it. NOTE: Rotate stator plate approximately the same distance as the marks must move. In most cases, the recoil starter housing, recoil drive hub, and flywheel must be removed to loosen the stator bolts and change the timing. On some engines, the stator plate
retaining screws can be accessed through the flywheel.
10.Torque stator plate screws and flywheel nut to specified torque. Apply Loctite 262 (red) to crankshaft flywheel taper if required. Refer to the Specifications section for torque specifications and flywheel installation procedure for engine type.
