reverse cam experiment
on the reverse cam secondary clutch any spring position beyond the middle hole is ********
green cat secondary for $$ is hard to beat, other copy cats on the market for more $$$
"When you use the cat green ( or copy cat from ??) more than middle hole adjustment you loose upshift. So if you have heat issues or slipping issues, and think you need to get viscous tight on that spring............ you need to to lower gearing, clean and align clutch's and made adjustments to run a stiff spring with as little preload as possible. Less helix, loose stiff secondary spring. Cats problem with this clutch was stoc, k the next hole is about 15 degrees plus of rotation. Real easy to go from not enough spring pressure to toooo much and go right past where you need to run. Cheap answer is two more set of holes so you have 3-4 degrees of adjustment.
Easy to do, but a brain teaser to explain. Back in the day lots of aftermarket infinite adjustments spring hole gizzmos. A not so secret big secret the yamaha tuners like al brought to make a good cat secondary.
So in short......if you have to go tighter than middle, you have other problems. So send me plate and $50 and I'll drill the holes, or check old post for free.
