Team secondary springs are measured at 2.2" and 1.1". The second # better reflects the amount of side force you will be working against at full shift out.
To some extent the stiffer pressure acts like a shallower helix. It helps provide more side force at full shift when the belt contact with the sheave is at it's least.
In a nutshell it will slow the up shift of the secondary slightly and speed the back shift. Requiring more RPM from the primary.
The more spring you use the more torque sensing your clutch
can be as it has a better hold of your belt at all times. The down side is you must have a primary setup that can pull the extra spring. Must be a balance between your clutches.
If you have to much secondary spring pressure, the clutch might not be able to shift out all the way. The primary will be trying to shift, but likely slipping.
I hope I explained that right.
