Secondary Helix Bolts breaking
sanderson
New member
Has anybody had there secondary helix bolts break and chew up the clutches ? I had this happen on a 08 Summit X 146. I would like to know if anybody else has had this problem. The bolts had loctite on them and they did not back out as the head snapped off.
Thanks
You must heat the bolt heads up good with a blow torch and then slowly loosen them. The loctite needs heat to deactivate it. If you do not heat it up you will break the bolt heads right off.
I wasn't trying to get them out. They broke while riding and banged around in both clutches and screwed up the faces.
