96 ultra BB with 56 gram, polaris black white spring and Team secondary with red/black 140-240. It seems pull everything down low well, but at altitude, it pulls the RPM fine out of the hole but I lose 300 ish RPM at oh 40-50 track speed. If I went with the 140-260 spring would I find 300 rpm or should I take a gram off the primary weight tips...Seems like I have the recommended helix and they are pricey so I am hoping the increased Sec. spring tension helps a bit with the back shift too. Is this enough? If not what do you think about a little more rate on the primary. As odd as it seems I might be clutched a little light on belt tension because my rpm does bounce around a bit.
thanx
Karl
thanx
Karl
