As many of you have noticed, the original snowest.com links are not working due to a server error that has proven hard to track down and correct. Until the problem can be fixed, here is a simple way to make any 'original snowest' link work.
Keep in mind that any recent link that is posted as snowestonline.com should already be working correctly and will not need this little modification.
There are 2 ways that you can manually correct the link that you are attempting to follow:
Option A
1. Right click on the link and select COPY LINK LOCATION
2. open a new tab in your browser
3. paste the link into the address bar
4. between "snowest" and ".com" add "online"
This is the function in the server that is currently not working.
Example:
Video For Tps Setting For Cfi Sleds http://www.snowest.com/forum/showthread.php?t=72725
Copy and paste into your browser
Add online to make the link look like this
http://www.snowestonline.com/forum/showthread.php?t=72725
Option B
1. Click on the snowest.com link
2. The window comes up as "NOT FOUND"
3. Add Online to the address: snowestonline.com
4. Press the enter key or push the go button to proceed to the corrected address.
Option A
Example:
Option B
