My father in law ran a bd turbo setup on an 09 m8 at sea level to about 2000ft, running 50/50 mix of 110 and 91 octane on 9.5 lbs. He had about 2000 miles on the sled before we put new pistons in it. There were no signs of deto and very little blowby on the rings. the setup was extremely reliable and would stomp all over my n/a D&D 1200
How was his injector duty cycle not maxed out? In my experience an M8 with no auxiliary injectors would be maxed out at 8 or so pounds at sea level no matter what fuel you ran.
replace stock with larger injectors
Is thier any way you can use a turbo on 91 @ sealevel.
what injectors can we use in the M8/M1000's to get a bit more fuel out of our pg setups ?
Lower your CR to 10:5 or 11:1 with a RKT or CPC head, and you will be good to go on 6-8psi @ sealevel...
