B
burgess
New member
So I bought two piston kits from two different sources. Both are labeled 2204322 on the boxes. One was in a small white box and the other was in a little larger cardboard box. One also had a smaller part number on the bottom of the box which was 17519369. They were both wrapped in the same paper and are visually identical aside from the numbers on the top of the pistons. I measured with a verneir caliper and can tell no difference. Might grab a mic from work and try it. Im just wondering if this is common for Polaris and if they will be fine to run together. Thanks. Picture attached
