08 m1000 rear suspension saggs horribly even with no weight on it. 162 track shock pressure 145psi front preload full.Dont understand it,BrothersM8 does the samething is this normal??? thanks in advance
Scot
Scot
I'm not lookin piss riders off, but open the Book that smooth talker gave you when u gave him 10g's !! If u think the way it looks in the parkin lot will get u 2 the top, well yes you can ***** about gettin put in the wrong group. Because u look as good as u think your sled does!
What?I had the same problem on my 09 hcr last year. My float had no oil in it, which was my fault, and I was told to refill every 300 miles to maintain top performance. I also had the front zero's pressure pumped up from stock. I think it was 190, and now its 230. It dosen't sag at all now.
My suspension was bottoming out real bad, and would sag when sitting on flat ground a bit. I'm 230 ish, and am not nice to my sleds. I was going to have the float revalved, but was told to try the float when theres actually oil in it. There was next to none when I took it apart. A very experienced cat mechanic told me to refill it every 300 miles, and put more pressure in my zero front track shock.
