Looking for a good starting point on stage 1 S/C for 10,000 ft. Its set to full boost so should make right around 10psi.
Did several short test drives today at 1,000 ft just to check for leaks and all that stuff. One thing that I couldnt tune out of it was right around 6 to 7000 rpm with very little throttle movement it would surge or cut out for a second. I thought maybe it was the TORS so I bypassed that and it still did it. The second issue was at that same rpm range and with steady throttle the air/fuel would jump from 12.5 to 17.1
I have seen a few posts now about the throttle return spring needing adjusted. There was only one time today the sled felt like it stayed accellerating when i let off the throttle so i will likely do something with that.
Last thing, Spark plugs. stock plug or the 10ek's and what gap. Thanks for any help. Eric
