RX1 Risers and Prefilters
Just bought a '03 RX1 w/ turbo. Any inputs to which riser works best or does it matter? Also, how much extra slack should I have on stock cable length? With the rear mount turbos, is it best to run the prefilter out of the plastic behind the seat, or leave in the plastic?
Thanks
run the filter outside. Helps it breathe better. i run my blower prefilter outside through the hood and i have no breathing problems in the deepest of snow
riser
check out truvert by chux limited. there is one on ebay. it is very strong and moves the bars up depending on the degree you use. i have one on a mountain max. if you want higher you can use 1x3 aluminum tubing bolted in the middle and go as high as you want.
