rx 1 won't rev up, surges
I got this rx 1 thats been sitting for a few years, only has 76 miles on it. mice ate the hand warmer wiring. the thing won't rev up like the throttle bypass switch is bad, but how do you bypass it to test to see if thats it?? thanks in advance.
Thanks to Mark at mountain express turbo. the bypass for the throttle is a switch that comes off the center of the carbs by the idle screw. follow it to the right side frame rail, unplug the two wire bullet style connectors, and on the harness side plug them into each other, that bypasses the switch. in case your carbs or cable sticks wide open it will do a rev cut-out so you don't crash and burn.
Except that wasn't it!! Mark Heard it over the phone and I told him the air box was off, he said it would pop and spit and he was right! WOW this thing won't run without an airbox!! thanks Mark and to everyone else.
