the cylinders on the 05 can be pulled with motor in...but i think the 06 cant...
good luck man..
This is correct. No-go on the 06's, go on the 05's.
Base gasket leaking...Check your upper crankcase/cylinder gasket surfaces VERY CLOSE. I just repaired a repeat offender that someone had rebuilt 3 times by an expert for base gasket leaking and found that when the motor had been apart, at some point, the rod must've jammed itself into the upper crankcase surface putting a huge bulge/burr on the leading edge. There was zero retention of the cylinder/gasket when removing the jug. This bluge/burr on the sealing surface wasn't allowing full contact of the surface of the cylinder.
Flat stoned, installed anerobic sealant, re-assembled, torqued to spec, it's now fixed.
Which gasket surface Dave, the base gasket surface?
What about the injectors? Do they need to be unbolted at the back before lifting up on the cylinders?
On the 05's the injectors go into the case only, that is what allows you to pull the jugs on an 05 and not an 06 while the motor is still in the chassis.![]()
NO they are on the casesWhat about the injectors? Do they need to be unbolted at the back before lifting up on the cylinders?
