Yes they will hit, you can cut them or have ice age machine them when you order the rails. Also run the ice age 2 wheel anti-stab kit with two limited straps. I'm basically running the same setup.
Basically replace your limiter strap cross shaft with the anti stab.I'll ask ice age if they know how much to take off. If not, do you know?
I guess I could switch drivers but polaris 'stock tension' sucks.
Thanks!
cut right in front of that.
I’m running oem pro rails with khaos geometry / anti stab.stupid question: is there any point to buying the khaos rails at that point if I'm just cutting them? Is the bend further down still necessary if I'm dropping the skid?
Both correct.got the rails and got the skid together
I'm assuming you guys with ice age khaos setups had to drill out the tips to get the antistab kits on? Itty bitty holes for the tips exist but nowhere near big enough for an antistab bolt
In other news, a 'long' walker evans eyelet seems to create the same length shock as a stock khaos one
Poke a sawzall in there.Just went for a shakedown ride. Something's hitting my drivers, I think it's the bigger diameter ice age antistab wheels. Gotta pull it in and check.
edit: ice age sent me uncut rails
sweet
