Does anyone know where to get these? I need them to mount on my airframes.
What would be the advantage to mounting scratchers to your airframes? A 3ft long scratcher? Use rail mounted scratchers like everyone else and call it a day.
A lot of sled rental shops do this. Use 2 screws tightened together to create a stop, then a third bolt to attach to the ski. About 4-4.5" bolt.Sounds like a possible breakage could really mess up a track.
Have you tried putting a bolt through the rear of your skis to shoot snow up? I havent tried it, but ive seen a lot of guys do it with good results. I believe they just run a longer bolt through the back of the ski with a big nut so when the ski travels on hard pack it drags and throws snow up...
Just an idea
for an R&D idea, run down to your local tractor supply center and get some hay rake tines and maybe heat and bend the legs some if need be but i bet you could fab up something pretty slick for nice and cheap!
