Rolled the sled and lost coolant
I rolled my sled and it was on its side for 30 seconds. Did see some blue snow around the sled. Is it normal for the coolant bottle to let coolant out if the sled rolls. When i rode the sled back it was hotter then normaly. around 170 - 175. Normal is around 131 F
Coolant is green not blue could it be oil? Might have induced a air bubble in heat exchanger causing flow issue exchanger(s) should have been very warm if coolant was moving thru correctly.
Sounds like coolant is engine ice also sounds like the system may have a leak. A pressure tester can be installed on recovery tank, will show were leak is.
