rmk 900 water temp sensor error...
If you have a multi meter double check that the sensor is good. It should read approx. 2400 ohms at 60 degrees. If it is good I would double and triple check any connection to make sure it not loosing contact.
Err???? what are you trying to read? Voltage? Resistance? Did you download the manual out of the sticky parts section?
You dont need the sled running to check it, just unplug the connector set meter to ohms and check across the two wires.
I just tried man....I'm not computer savy enough to copy the couple of pages with the wiring on them
