RKtek drp in kit
I have a 2014 800 Pro with a rktek rev-2 drop in kit with a 13.5 comp. head . and a boondocker control box.I am heading to cook in a week and we have no snow where I live ,so I can not try it to see if the fuel settings are good. I am wondering if rktek settings are fairly good . If someone could share their setting with me , I would appreciate it. Cook is 8,000 to 10,000.
boonie
if you want i can pm you the #'s from my 13 with the same setup based on 6-7000ft. you will have a decent base line that you can trim while you are there. running roosters for weights.
I just had the RK TEK drop in kit installed. I still need to get a fuel controller. RK TEK says they run the Boondocker control box but my mechanic is convinced the Power Commander V and Auto tuner is the way to go. I'm not sure as I'm a newbie. Does any one have an opinion on this? Supposedly the PCV with the auto tuner only takes one trip to get it set up and then it is spot on because of the Auto Tuner.
How has the Boondocker Box worked for you guys? Are you happy with it? Would you do anything different now that you're set up the way you are?
The elevation I ride at is 8000-1000 feet
I'm excited to try this upgrade out!
