J
jrk
New member
I recently installed the RKT piston/head kit in my 2012 PRO R switchback. I had high hopes and aspirations that the kit would improve durability and performance. I have approximately 700 miles on the kit and I do have some concerns.
The sled prior to the upgrade with the stock head/pistons, the sled used to operate in the 120-125* temperature range…..usually closer to the 120 mark. Since the upgrade the sled runs anywhere between 128-134*F. Never any less than 128*. This is roughly 10-15 degrees hotter than it normally ran before the install in the same outside temps and snow conditions. The PRO R switchback has substantially more cooling area than an RMK and these temps I recorded are not on packed trail……..these temps are taken driving across a smooth field with 6-8 inches of snow
I’ve also noticed that when the sled gets up to that operating temperature, the RPMs start dropping off like as if it is losing power or running rich. There is nothing ailing this sled mechanically and it has LOTS of compression and the VES are not plugged. Sled has 1700 miles.
Something just doesn’t seem right. Having a lot of trouble clutching the sled because of it. I’ve had to back off on some finish angle on the helix or decrease some primary weight to compensate.
I was under the impression that the piston/head kit was to gain an additional 10-15 HP over stock….if it was to gain 5-8 HP I would have been happy…..it was the durability I was after! One would think if that was the case, I should be adding weight and helix angle to the sled, not taking it out.
I would have also assumed that the head would be do a better job at cooling……not making things worse.
At this point, I’m not sure I have gained anything with this kit.
It seems a lot of guys were putting in a thermostat bypass kit to keep these engine cooler, but most of those were on an RMK because of their lack of coolers......perhaps the crappy factory thermostat is the limiting factor with the piston/head kit?
Perhaps it needs a thermostat bypass kit like the BRP retrofit or a terra alps thermo bypass kit to keep the temps in check??
Could it be the temperature is causing the sled to go into a “self-preservation” mode because it running too hot, therefore retarding timing and dumping fuel in?
Perhaps with the temps closer to the 115-120* degree mark will give my performance back?
I know there are a lot of guys out there using the kit, so there must be someone with similar issues?
