2012 Pro RMK .The drop in kit is already in...runs awesome. Got a can and pipe on the shop floor. How has this combo worked for people,looking for insight! Thanks Randy
edavis, weren't you trying the vi-pec? You running a BD or PCV now??
I'm sticking with stock pipe on mine, at least for this season.. plan to do a big bore next season so just fine tuning and fixing little issues with this season's machine while I save up for a bigger build next year! Trying to decide between a BD box and a PCV though...
Ill give Kelsey a call on my days off. What started all of this is the insulation on my stock pipe has all fell out and the shielding rattles like crazy. My friends pipes are all tight.strange. I had a boondocker box but found it wont work on a Polaris so I may just fix stock pipe and sell the pipe can and boondocker box. thanks again all
I have the RKTek drop-in stacked with the SLP stg.2 kit, running at 0-3000ft. (12.6:1 head)
I'm having trouble when stabbing the throttle, it hits det alot.
I started out with the stock stg2 map for my PCV, but that was somewhat useless hitting det all the time.
So i loaded the stg.3 map, and that helped a bit, but not near good still getting det.
I've started adding fuel from that map, and have the det-issue somewhat better, but still not perfect.
The sled can bog down at times, and sometimes it hits det.
I'm looking for some input from you guys regarding my map, and any help would be great!
I realize i should be running a AF-gauge, but I'm currently not..
Fuel is 98okt pump gas.
Stock stg2 map:
mod'ed stg3. map:
Thanks for the reply guys
Yes, it's a '13 Pro. I've calibrated the TPS and did the "Throttle pump activation" as the SLP-spec suggested.
The thing is, my det problems went from terrible to almost good with just adding fuel to the map.
I pulled the plugs and it did not seem to be rich at all.
I just need to know if I'm way off just adding fuel to this setup, or I will need higher octane to solve it.
Yep, guess I'll have to order a AFR system.
I looked at the AFX from NGK as you suggested, however this was stated in their manual:
The AFX is designed for 4-stroke cycle engines, and will not accurately perform in a 2-stroke cycle engine. Due to scavenging of 2-stroke engines, the true AFR reading becomes distorted. The nature of 2-strokes is inherently one that is not compatible with exhaust gas sensors.
Any comments on this?
It may be rude of me to ask, but would you share your map?
Btw, did you do any testing with the stock exhaust vs. the slp?
This brings up a very good point about AFR gauges, and their accuracy in a two stroke sled...Originally Posted by Eivel![]()
