do you think it will be good if doo's next chassis should be more forward the same or back off a little foot placement on boards asideSound like skidoo wins this topic.you can go farther forward if you want to.![]()
I think the biggest thing guys need to learn, is that just because the foot wells are forward doesn't mean you need to stand in them all the time.
I do findmyself on downhill maneuvers wanting to get my feet farther forward. ON the doo, I love that, I can shove my feet up in the little footwell notches and get it to roll into a downhill roll super easily. That being said it took me a minut to realize most of the time I need to stand back just a little as riding around with your feet jammed forward created a very darty sled with too much input from the nose.
Each sled is different, and dont try and say the sled doesnt work because you hopped on it and tried to ride it like your sled. They each take a second to get used too and have their own riding style going with it.
If I was a bettin' man I would bet that ski doo has the engine behind the jackshaft on the next mountain platform. 2017?![]()
I guess i have to disagree. The closer you are to front end and footwells the easier it is to tip up. The closer you are to the main mass of any object the easier it is to move. Imo if you have to move the skis and spindles way forward that is a tell tale sign they went too far.My thoughts from the 36" wide, 2-5/8" forward Cat front end thread: It seems we are starting to hit the point on current mountain sled chassis from all the manufacturers where "rider forward" has diminishing returns without mods like this. Moving the rider forward puts the center of mass closer to the rider and makes it easier to control. The negative is that when you are initially tipping the sled over, you are closer to the wider part of the sled (a-arms) and it takes more effort initially to get it over. Moving the spindle forward and narrowing the stance then makes it easier to tip over. I'm guessing the next thing we will start noticing as the trend continues is that we are making the sled longer, which in turn will make direction changes tougher. Then I imagine the next "revolution" in mountain handling will come when a manufacturer figures out how to move the motor and drive train back and put it right under the rider and shortens the sled back up!
