Reverse delete on Nytro?
I would just look up the parts listing for the non r model and the r model and just cross-reference the part numbers to see which are the same and which are different.
I too sometimes keep the "old" parts like when you buy the cheat'n parts and keep the stockers...only to throw them out later and say "what the f did i keep that for" and "that’s just taking up space" i guess if i was going to get rid of reverse i would be sure i dont want it. for the same reason i dont get reverse and added it on..because i just dont know if it would be used enough to cover the cost and the time to do it.....but if it was free then...... it might be!
You lookin to save the weight? Loss would be in the 6 lb range if I remember right. IMO there's good weight and bad weight. Reverse is good weight.LOL
M5
Oh lord, Just leave the reverse in there and put gas in it ride it. You will need reverse for the spring and that sled deck spring days.
Jim
M5
actually it 9 lbs....had the dealer looked up both shipping weights.
Problem is the gearing options are very limited.
I am not comfortable running anything smaller than the 19 tooth top gear with boost.
I didn't have reverse for the first 5 years I had a sled deck so I think I can survive without it again.
I run 19 40 with reverse on my turbo and it's worked pretty well for me. What gearing are you looking for?
M5
