Hi, i have an 06 600 ho sdi Adreniline, and I'm sorta new to snowmobile clutches. I want to get the clutch to engage at a higher rpm. I have hard that all you need is a 30 dollar spring, and I would much rather do that than get a clutch kit. It engages at ---- ( I'll check tomorrow) and I don't know what a good rpm would be (for the clutch to engage) at something higher than stock to do wheelies and such. What size spring, compression, etc would work on my stock sled, with as little work/ tuning as possible. If anyone has done this how did it work and what did u use and where from?
I am also considering to lower the gear ratio. What would work with the stock chain and get me some better bottom end punch?
Thanks!
Thanks!
