My steering was getting more sloppy as the year progressed, I assumed it was a loose nut at a ball joint on the steering rods.
Pulled the motor last night and started to inspect steering system.......all ball joint nuts were tight, all the ball joints were in great shape, very minor play at the u-joint on the steering column.
As I was scratching my head, Miko700 (Mike) grabbed the bracket and housing that attaches the steering post to the rear bulkhead..........1 rivet was completely gone, the others had worbled out so that there was almost 3/8" of play in all directions.
Thinking new, larger, stronger rivets was the fix, we drilled out the old ones and found........................
Major cracks and stress damage over about a 6" sq. area around the inboard mounting tab.
The problem in repairing is that the rear cooler is right behind that bulkhead, then the tunnel. I was not going to drill out all the rivets, remove the bulkhead from the tunnel, remove the cooler and rivet a backer plate on the cooler....there had to be a easier way.
After checking the clearances to the back of the motor from the bulkhead I decided a 1/8" x 8" x 5 1/2" aluminum reinforcement plate would do the trick.
I drilled 1/8" holes at the end of all the cracks in hopes of stopping any further cracking
I drilled out 5/16" holes so that the plate would fit over existing rivet bodies that were riveted from the cooler side in toward the engine compartment during original factory assembly.
Measured and drilled 3/16" holes for the new rivets in the plate that match the mounting bracket and dry fit.
Now, I'm waiting for rivets... http://oftracing.com/Store/index.php?main_page=product_info&cPath=81&products_id=216
These mushroom up on the back side giving a superior grip both front and back.
I'm going to:
I'll post more pics when I over drill and mount the plate and bracket/steering assembly.
This is definitely something to check on all IQ sleds. We have all heard about steering posts snapping and ball joints breaking........when/if you pull your motor, give this area extra attention.
I'm going to:
- Over drill the the existing bracket holes in the bulkhead to approx. 3/8"......larger diameter than the back of the new rivets
- Use the new Oft Racing rivets to securely mount the aluminum plate to the bulkhead.
- Mount the steering bracket to the new aluminum plate in the 3/16" holes shown in picture that will be directly over the over drilled holes in the bulkhead to give the rivet room to expand out and bite the new plate.
