Try an impact driver, the one you hit with a hammer. It will come right out
with heat, that's what we use
Occasionally a drill and new screws works good too. No loctite and not very tight.
Plug weld a nut on them then back them out with a wrench while hot
I have used this method also except I used a small sharp wood chisel. It will bite (cut) into the bolt head. Fix chisel with bench grinder when finished. Keep it for next time.One trick I use is to take a sharp center punch and put a good mark in the head of the screw close to the edge of the head. Then position the punch at about a 45* angle and use the punch to try and get it moving. This works very well since you have moved the turning torque to the outside of the fastener instead of right in the center. Good luck. Eric
