Chumbilly, not you got me thinking again, what is thediff beyween manual mode rekluse and auto mode rekluse?
They are stall proof. They can make you lazy (with using a clutch lever). They are easy. They can creep when idling. They will keep the bike running in a tip over. They are hard to start in gear. They are expensive.
The people that have them like them.
Me...not so much. I am a bike guy and can work the clutch lever fine. It takes some of the fun out of the "bike" thing.
Most of our Priest Lake group that has had them no longer does.
Some still swear by them. Kinda like a Harley rider. If you spend big $$ on something it has to be great or you look bad.
I've ran the Rekluse 2.0 in my 2006 YZ450 which I've only used for enduro. The 2.0 is the kit that replaces 3 stock clutch plates. It worked great for about 60 hours but my clutch is now completely pooched in the bike. I've replaced all the plates (steel and friction) but for some reason the bike does not move when the clutch is released. I can sit there with the clutch lever out, rev the bike and it will slowly creep forward in any gear (this is without the recluse installed even). I'm completely baffled at this point on what the problem is. Maybe my basket is to notched and needs replacing.![]()
450 are known to notch baskets, replaced plenty with and without A/C.
Did you set your free play gain after you re did your clutch plates?
That's the weirdest part, I completely loosened my clutch cable as far as it would go to where my lever had no resistance and it would idle in first gear even without the rekluse. My bike shops in town really aren't great, they wont let me talk to a mechanic and the parts guys are just parts guys they don't know much about that stuff. Its going to suck if I spend almost $400 on clutch parts and the problem isn't fixed. I sure as hell don't want to spend a grand for the shop to look at it. After all this im a little scared to put a rekluse in my new bikes...
Mrdiesel, Torkd doesnt even have a recluse disc in, reread his post. Torkd, you must have left out a fiber or steel plate. Pull the cover off, you should not be able to wiggle the tabs on the fiber discs at all. When you tighten the pressure plate springs, the whole clutch pack is then bound together, assuming the clutch cable has slack in it. Worn basket finger symptom would be the clutch NOT releasing when you pull in the lever and want to stop. Eng dies. That's not whats causing this. If you can wiggle the clutch pack, pull it apart and count the pieces. You must be short one.
