reinstalling 900 rmk motor
I had to pull the motor out of my 06' 900. The water pump was leaking. I need to know if some one could advise me on how to match the 4 wires on the fuel injection back up. They pulled apart by the sterring post and they all look like the same connector. The wires are marked U mag,L mag, U pto, L pto. The wires connected to the fuel lines all have the same markings on them so i don't know how to hook them back properley. If some one could help with this problem i would really apperiate it.
I might not be understanding your problem correctly, but you just match the correct wire to the correct injector. You have the Upper Mag, Lower Mag, Upper PTO, Lower PTO. Mag side is on the right side of the sled, PTO is on the left.
900 install
Thank you for the information. I was did not know which was left or right. I will get my motor back from the shop hopely this comming friday. Then i hopefuly can get it put back in. Obviously this is the first time i've had to do major work on my sled. It has 1900 miles on it and has been awsome. Thanks for your help.
