Rebuilt 800 Polaris cranks:
$600.00 plus $20.00 shipping from zip code 83401.
Cranks are rebuilt with all parts checked and replaced if not in spec.
Big bearing kit on all cranks. Welded on request for a cost of $75.00.
Case mod is required, case must be drilled to let more oil into bearing.
This mod is simple and can be done by anyone by drilling a 15/64ths. hole
between where the two bearings set in the top of the crank case on the PTO end.
By drilling through the case you should come out into the oil hole or the casting indent (depending on age of case) on the top of the crank case.
I check my PM's about every week or two.
my phone number is (208) 520 8070.
email address is acss@cableone.net
when emailing make sure to put "cranks" into title.
