So I lost a crank last year in my '11 Pro RMK. Rebuilt it with a hotrods crank and a RK Tek drop in kit. Ran for about 10 minutes, didn't sound right so took it into local shop. They stuck a camera into the cylinders and revealed they were scored already. They said not enough oil. I started hearing all sorts of things about RK Tek pistons not being the best so I decided to rebuild it stock, being very careful to make sure the oil lines were primed and the linkage arm from the throttle body to the oil pump was hooked up correctly and oil the **** out of everything when I assembled it. This time it lasted about 150 miles and the cylinders are all scored again. Is there a way to test the oiling system? This is getting expensive so any advice would be helpful.
