Rear Superclamps
plastic rear superclamps aren't as strong as the old steel ones, but they are so quick and easy.... so worth every penny at the end of the day:D
Rear clamps=WAY better than a strap. You just have to make sure you have metal backing underneath your deck at that point. Don't anchor to only plywood decking. Go through the framing.
Plastic hooks suck. They break and then you lose your clamp on the side of the highway. Make sure they are metal. I think Randy is ONLY using metal hooks on them now.
See my thread about them from last spring.
Got em, work great. wouldn't use strap again.
pro- super quick and easy
con- Depending on the roads you drive to get in, your sled can still slide a bit backwards, at least mine did. What I did was put my front superclamp on the back part of the ski so it couldnt slide back, also can't go forward b/c of the headache rack on my deck. Effectively not a con for me anymore.
