It’s all in there correctly I believe , looked at a few other pics from around the Internet and the shock is above the cross member .Correct me if I’m wrong but in the pic it looks like you have it installed wrong. That upper mount should swing down 180 degrees and shock will be underneath that cross member.
Rear shock is touching the track , had the shocks revalved , put it back in and noticed this.
800 axys 163
Powerclaw track on it
What would cause this ?
I’m going to guess you have a bent rear torque arm also.
I see you have an add on rear suspension coupler.
Are the shocks upgraded?
Or just stock monotubes?
(Bottoming out hard can bend the rear torque arm)
Revalved monotubes ... only 500 miles on skid and I don’t jump or send it.
