snowmobiler
He’s just asking why they swirled the grooves.
“Rifled”
I’m going to guess that piston seal wear is the reason.
(Straight grooves make concentrated wear points)
ri·fle1
ˈrīfəl/Submit
verb
past tense: rifled; past participle: rifled
1.
make spiral grooves in
5.
to cut grooves in
https://www.google.com/search?q=rif.....69i57j0l5.1599j1j4&sourceid=chrome&ie=UTF-8
https://www.dictionary.com/browse/rifled
C'mon boys!~ Vocabulary is important. Use it.
From my POV, that's just going to unscrew the piston or create more wear. This is why I'd like to hear from Raptor on it!
Here’s a little look at the inner workings of our new Kinetic line of shocks. As you can clearly see from the V1-RC photo we have channels machined on the inner wall of the shock body. What that does is allows the shock fluid to bypass around the main valving piston as the piston passes through the Ride zone.
The options that we have are endless. We have the flexibility to change the percentage of flow with the depth, width, number, as well as the length of these channels. This combined with a new Anti Pack piston that houses a check valve inside one of the rebound circuits, makes for an incredible amount of control in the Ride zone.
The benefit with having a Bottom out zone is for those big nasty hits maybe expected or, more importantly, not expected. What we typically do with the V1-RC is we have 30% of the remaining part of the stroke as a Bottom out zone. How we achieve this is by ending the bypass channels 70% of the way down the shock body. This forces 100% of the fluid that was bypassing in the Ride zone through the main valving piston causing a significant change in pressure. We refer to this as shifting. We pick when the shock shifts as well as how hard it shifts between these two zones.
This shock design if often compared to those on a trophy truck with the exception that ours being an internal bypass vs an external bypass. The sheer beauty of these designs is they are a self-contained coil-over and need no “in flight” adjustments, no electronics and no last second button pushes. You simply hit whatever is in front of you.
Why does this all matter, it gives the rider a more compliant ride in the Ride zone with better bottom out protection in the Bottom out zone. This will give you much better control of the vehicle with far less effort and far less rider fatigue.
As you can imagine, it gets very busy for us this time of year and we don't get to spend as much time on the forums addressing questions as we'd like. If you have any questions, don't hesitate to reach out to us by phone, email or on any of our social media channels.
Hey look who changed their username.
Don’t make the same mistake every other manufacturer does.
(Get sucked into an argument with a troll and dragged through the mud)
Thanks for the tip. It was an old username I had before I started at Raptor. Figured it would be easier for customers to recognize if I changed it up and didn't realize we could until Christopher helped me out a few days ago.
We try not to argue with anyone but we do try to correct any glaringly bad info when we get a chance.
Always best to give us a call when you need info.
Sent from my Pixel 2 XL using Tapatalk
