For those that have actually done the switch!! Did you notice any change in the counter steer pull over from low speed. I'm looking at backing the spring pressure off to the minimum and like the idea of adjustability.
I'm Raptor'd on all 4
I noticed a world of difference in all aspects... Just sitting on flat ground the sled will squish from side to side if you lean side to side... My Walkers didn't do that. I'm mostly amazed by my front Raptors, the rears I'm not as blown away by but they still RIP!
That's where I'm at. Spoke with Jake @ raptor for a while about this. It's not the shocks, it's the skid geometry. Considering going to a full kmod but having a hard time justifying the expense right now.
Shocks flat out rock. I've never ridden a sled where the harder you pound the shocks the better they perform - and you can actually feel them working.
I may have a set of rear shocks for sale, still on the fence though.
Have a look at this video...
Rasmussen at :50 and Whelpton at 1:39
You can see that the sled is on edge as compared to having the shock compressed on that side... This allows the shock to still have travel to do work if you hit irregularities in the snow.
It is more work to learn it... but worth it IMO.
Have a look at this one...
at :28 , :48 1:13, 1:18 ... you will see that on the extreme side-hill... the uphill front suspension is basically still fully extended... the sled is on Edge... not "squatted" on that side.
THEN, FINALLY HAVE A LOOK AT THIS ONE...
Bret, at 1:54 seconds... "bumps" the tree on an extreme side-hill... the shock/suspension absorb the impact and then extends agian... If the shock was "squatted" on that side.. there would have been effectively no travel left to deal with that obstacle and he would have been bucked down the hill.... Pretty amazing move!!
