I'm curious about which to run in my BN turbo pro. I run a 70/30 ratio. Pump gas/race fuel and the sled runs great and I hate to screw it up.
Ive run both and cant tell much difference between the two. But if it aint broke dont fix it !
in my area the airport sells AV for 6.93 per gal. Sunoco 110 is 7.25 by the barrel 7.50 by the gal. so the differece in cost per tank is a couple bucks.
It is important to do your homework on what fuel to run. I agree, don't spend money on a turbo and then go cheap on the fuel. On the other hand, running to much octane is not beneficial and often degrades performances. So just running straight *** octane can hurt performance. I had to back the octane off for my elevation to help with idle issues and throttle response. Backing the octane off I got better throttle response, idled better and got more performance. I was able to get the egt's up higher where I like to see them. There is a lot of variables, so you can't really give a blanket policy of anything over "x amount of boost" you should be running "x amount of octane." I agree its best to start with too much octane and work from there. Here is a good thread with lots of info.Yours will be broken a lot faster than the rest of us that run straight c12! Av gas burns way hotter, if you were to tear a motor apart that has been run on straight c12 vs one ran on av gas you will notice a difference…anything over 11lbs should be run straight c12..why spend 9k on a turbo if you can't afford the gas? Chances are you won't be able to fit the bill to rebuild a blown motor if you can't afford the extra $$$ in good gas! Something to think about. UNLESS..you run 7-8lbs of boost which THEN i ask why waste your money on a turbo?
http://www.snowest.com/forum/showthread.php?t=220800&highlight=avgas
