Quick Drive Gearing Options
Yes it is more than just word of mouth. I spoke personally to one of the engineers at Denver snow show and he said I was 100% correct on the design. I know if you called and spoke to them they will tell you the same. Been using there belts for the past 5 1/2 years this way and they work perfect.
This is taken from the Poly Chain design manual.
Use of idlers should be restricted to those cases in which they are functionally necessary. Idlers are often used as a means of applying tension when the center distance is not adjustable.
Idlers should be located on the slack side span of the belt drive. General size recommendations are listed for inside grooved, inside flat, and backside idlers. In some cases, such as high capacity drives utilizing large sprockets, idlers as large as the smallest loaded sprocket in the system may be more appropriate.
Just curious, anyone ever broke one of TKI's belts. I don't own one, but they sound like a solid setup. Also what about his tensioner on the stock belt. Does it apply tension to the belt or sit off of it like the F.I one?
Can i use proride gears on axys with stock belt. 22/43 to 21/44
Others have done exactly that and have reported no issues. I'm going to do it on my personal sled as soon as I get time, which might not be until next weekend. Eric
What about driveshaft. Can i use -13 indy steel shaft on pro axys. Because i want 7tooth 2,52" drivers. Is the sprocket spline same on chaincase and belt drive.
I've got this setup on my 155. About 100 miles on it with not problems and I think it works greato, I did a more aggressive helix in my secondary as well which I think it needs to load the engine
