"Preload" in a fastener can be hard to wrap your head around.
Preload in a bolt can be difficult to understand... It took me a long time and a few goes at it.
A connecting rod in say, a modern high performace V8... the connecting rod bolts are not just torqued but measured for stretch/preload values.
Lower hp con rods simply have a bolt and threaded bore design... high hp applications will have a longer through bolt... The presentation that I was given by an engineer at Carillo (and also ARP) was that the longer length allowed better preload factors to be built in.
The clamping of sprocket to the shaft/bearing-race will not even come close to that of a demanding con-rod cap...but the engineering is still there.
Here is a good, easy to understand presentation from ARP:
A broken bolt will not work to keep the drive together... one that will bear the cyclic additive forces of the assembly, in use, WILL keep the assembly together.
The proof will be in the riding, this season, in the consumers hands.
At least the engineering behind the change is solid
TIf a longer bolt on the 16 allows it to flex more or stretch more, this is not good either. I can't see how it will fix it but I hope I am wrong.
It is a fundamental engineering concept that the force in a bolt in an ideal preloaded joint will remain equal to the preload until the externally applied force exceeds the preload. Then the force in the bolt will be equal to the external force. This means that fluctuating external forces will not cause fluctuating forces in a preloaded bolt as long as the preload exceeds the external force. The result is that fatigue failure will not occur.
