Question
I have an 900 EFI sled that hasn't ran in about 6 years but was in storage area since then..there seems to be no gas in the tank and very little oil..do you think it's safe to refuel and put some oil in and start it? I don't wanna blow up my motor lol.
Everything else seems very clean under the hood.
Better pull the fuel line at the fuel rail and put the line in a glass jar and pull it over , probably gonna get black goo from deteriorated fuel lines . If you just fuel it and pull it over you will plug up the fuel injectors and will either have to replace $$$$$$ or have them professionally cleaned and repaired . Hopefully fuel pump isn't dried out won't know till you check the above first .!
This^^ also pull the oil line at the end of the tank and drain it. Put 2 oz of oil in the fresh gas until you know it's taking oil threw the pump too
